Maintainence ?
Old Jan 10, 2005 | 02:40 AM
stephen4785's Avatar
Default Maintainence ?
What kind of oil should I use(Im a big fan of full syn) and what should the tire pressure be?
Old Jan 15, 2005 | 01:21 PM
mindz's Avatar
Default RE: Maintainence ?
Tire pressure- Look at the tire it will tell you, I run 42lbs in mine(Bridgestone Battleaxe's)
Oil- Im running 10w-40 Honda oil(the red bottle) just b/c it seems to do fine and the bike is still under warrenty so if something did happen I could show the recipts of the oil to prove it(just in case), As far as full synthetics, i havent ran them in my bike I do know let your bike brake in properly BEFORE using full synthetics. Also, I've read post by other people complaning of the clutch slipping b/c of the use of full synthetics. But as for that subject I couldent tell you why or which bikes,etc. Hope that helps some.
Orangebutter
Mar 13, 2007 09:41 PM
stephen4785
Mar 17, 2005 05:17 PM
stephen4785
Mar 13, 2005 09:48 PM
