Loud Clank shifting into first
Whenever I am at a stop, after the bike is warmed up, when I shift into first it seems like the gear engaging makes a louder noise than it should and the bike jumps forward a little bit. I don't know if that's just how it is, or if something may be wrong. When I am slowing down to a red light and shift into first it doesn't make the noise or jump. I've tried depressing the shifter differently and it doesn't really make a difference. I know that the CCT is going bad on my 2002, it's got 18k on it, not sure if that would be related to the issue I'm having.
I am in no way an expert, but I think it could be related to how bikes gear linkages change directions so often. It may sound silly, but think about it. When you are in 2nd to 6th gear, you go from low to high (the pedal) then back down to down shift. But first gear, since it is the opposite--high to low, could maybe be why it has something to do with the clunk.
However someone here on the forum made a thread on when changing your clutch that you can go even deeper to change a small part to get rid of a lot of the clunking noise. However, many have said that it is not necessary.
