Lost Key
Old Mar 25, 2008 | 04:21 PM
b16matt's Avatar
Default Lost Key
SO... I lost my key. I got the ignition switch off. What number does the locksmith need or de I need to de-solder the wires and bring him the ignition?
Old Mar 25, 2008 | 04:53 PM
brveagle's Avatar
Default RE: Lost Key
take the lock cylinder off your seat. easier
Old Mar 25, 2008 | 08:43 PM
letsride's Avatar
If you have the ignition switch off then disconnect it at the pigtail and take it all with you,the code he needs is the last three #'s or letters and try it in the switch make sure you can lock the ignition.A good locksmith can do it in about 10 min.
Old Mar 25, 2008 | 10:45 PM
Icefox's Avatar
If your bars aren't locked you can also remove your ignition cylinder and take itto a Honda dealership and they can help you out there too, that may or may not be cheaper than having a locksmith do it...
Old Apr 1, 2008 | 04:02 PM
b16matt's Avatar
WWOoooohoooo took it to the dealership. 4 dollars for 2 keys.
Old Apr 1, 2008 | 06:27 PM
patman's Avatar
Do they give you Honda keys or some no name one? My bike came with one non-honda key, looks dumb, I want at least a pair of keys with the wings on them.
Old Apr 1, 2008 | 06:38 PM
ReSpEcT's Avatar
Take those keys that the dealer cut you and put them away. Get some copies of those keys made at ur local locksmith shop....Later on its ALOT better to dublicate the original, than it is to duplicate the duplicated keys. The cuts of the depths vary generation after generation. Which means eventually after a few duplications of a duplication, it'll be a POS key......I still have ALL my original keys and never use them.....=-)
cesarsanch2
Sep 22, 2012 10:09 PM
kinglee86
F2 Tech
24
Feb 22, 2011 12:49 PM
gammarat1
Apr 14, 2008 10:03 AM
bluestanger66
May 23, 2007 01:26 PM
