At a lose
Old 03-26-2011, 08:06 PM
scooterc14's Avatar
Default At a lose
Ok guys ive done everything I know how to do. On the way into work the other day the bike was running extremely rich. Backfiring when you decelerate and such. Then it will stall at a light. I'll pull in the clutch to stop, the RPMs will dip to 500 and stall but the bike will start right back up. It throws a code every now and then but not consistently. The code shows teh MAP sensor. I just pulled everything apart today and put it back together. Bike started fine, idled a lil low for start up but picked up. Warmed the bike reved it to around 6k let off and RPMs dipped again but didnt stall. Did it a second time and it shot a foot flame out the exhaust. Any ideas? Im getting antsy. For the record I disconnected my PCIII also.
Old 03-26-2011, 08:32 PM
backyardmechanic's Avatar
sounds like fouled plugs to me
Old 03-26-2011, 08:36 PM
scooterc14's Avatar
Just changed those out today. Wondering if its timing?
Old 03-26-2011, 09:32 PM
what kind of bike? maybe the regulator is toast?
Old 03-26-2011, 09:47 PM
scooterc14's Avatar
its a 2005 CBR600 f4i. I think I have around 28k on it. Idk if it helps but im running a two brothers and k&n filter and PCIII. Regulator? what does that control?
Old 03-27-2011, 12:39 AM
spoolie25's Avatar
a code is a code fix whats its tellling you is wrong. sounds like your having a fueling issue. if it was timing the bike would run like crap at all rpm . if its says thie map is bad replace it
Old 03-27-2011, 07:42 AM
xricer's Avatar
+1 new map sensor
Old 03-27-2011, 08:42 AM
scooterc14's Avatar
Correct me if im wrong but if it was all the MAP sensor wouldnt the code light come on every time I started it? Only throws the code when its a cold start. THe engine will idle at 1000 RPMs for a bit then rise to 1700.
Old 03-27-2011, 10:13 AM
the fpr regulates the pressure the fuel is going into your cylinders.
Old 03-27-2011, 11:16 AM
LJ Harp's Avatar
Official CBRF Decal Man
Have you even tried remapping it? Sounds like what's giving you hell.
Quick Reply: At a lose
