At a lose
Ok guys ive done everything I know how to do. On the way into work the other day the bike was running extremely rich. Backfiring when you decelerate and such. Then it will stall at a light. I'll pull in the clutch to stop, the RPMs will dip to 500 and stall but the bike will start right back up. It throws a code every now and then but not consistently. The code shows teh MAP sensor. I just pulled everything apart today and put it back together. Bike started fine, idled a lil low for start up but picked up. Warmed the bike reved it to around 6k let off and RPMs dipped again but didnt stall. Did it a second time and it shot a foot flame out the exhaust. Any ideas? Im getting antsy. For the record I disconnected my PCIII also.
sounds like fouled plugs to me
Just changed those out today. Wondering if its timing?
what kind of bike? maybe the regulator is toast?
its a 2005 CBR600 f4i. I think I have around 28k on it. Idk if it helps but im running a two brothers and k&n filter and PCIII. Regulator? what does that control?
a code is a code fix whats its tellling you is wrong. sounds like your having a fueling issue. if it was timing the bike would run like crap at all rpm . if its says thie map is bad replace it
Originally Posted by spoolie25
(Post 1031174)
Correct me if im wrong but if it was all the MAP sensor wouldnt the code light come on every time I started it? Only throws the code when its a cold start. THe engine will idle at 1000 RPMs for a bit then rise to 1700.
the fpr regulates the pressure the fuel is going into your cylinders.
Have you even tried remapping it? Sounds like what's giving you hell.
