Little help with the brake lighting.
Old Feb 7, 2007 | 01:34 PM
alekinci's Avatar
Default Little help with the brake lighting.
two month ago i noticed that my brake lights dont turn on for either the front or rear switchs. i havent check the fuses or the bulbs yet sinceits cold in ny right now. however, other than those two elements is there anything else that can cause both the front and rare switchs to stop my brake lights from coming on?
Old Feb 7, 2007 | 01:45 PM
Leveltwo's Avatar
Default RE: Little help with the brake lighting.
i know the rear has a pulley on the brake lever that regulates how hard the pedal has to be pushed for it to come on, but if the front and rear isnt making the bulb light up, then its probably a bad wire or bulb...also check the fuse before anything else like you said
Old Feb 7, 2007 | 03:42 PM
Tahoe SC's Avatar
if both don't come on...your biggest culprit is the fuse.
check that one first...with the key on of course.
Old Feb 7, 2007 | 03:51 PM
Candymanmo06F4I's Avatar
THe fuse is more then likely the problem
Same happen to my after i got it recoverd. Thought they mesed up all the wiring till i checked the fuses and saw that the headligh and brakes were both blown.
Old Feb 7, 2007 | 05:30 PM
alekinci's Avatar
Thanks guys. As soon as it gets warm thats the first thing ill check in to.
WARstunter
Feb 27, 2013 06:58 AM
espelade
Aug 19, 2010 08:53 PM
CBRfenatic93
Oct 4, 2009 12:22 PM
1badfish
May 6, 2007 12:34 AM
Cry For The Devil
Oct 4, 2006 04:51 AM
