So I'm new to riding...
So I was riding home tonight andIaccelerated reallyfast up to 80 mphand my turn came up quick so I started to apply both breaks, (I was somewhere between 3rd& 5th gear)then I pulled the clutch all the way in andpushed down on theshifter andit began to do what seemed like a bit ofslightly violentrattling around andmaking a lot of rattling noise,then after I slowed down more I down shifted again and itfelt like it dropped into gear andit stopped. My questions are these 1. What the hell was that? 2. Should I be concerned?
RE: So I'm new to riding...
Sounds like rear wheel hop to me. Downshifting while at a high RPM and not matching RPMs and or braking hard enough on the front to unload the rear tire so that any little rear brake will lock the rear tire. Sounds like you need to work on "riding" before dicking around. If you cant properly handle the bike from that speed, simply dont do it. Learn how to handle that thing first. And yes, if you continue to do it with out knowing what you are doing, you will crash. So yes, be concerned.
yes you are getting picked on, but its because we dont want to hear a new rider going down because of inexperience. take your time, and be easy on that rear brake, its not the same on the sportbikes as it is on any other bike. sportbikes will lock up easier, and that isnt good
i think tahoe is right, i believe your were stuck between gears. i would use engine breaking + little help form the front break to slow down and then when your around 5-6k rmps start shifting down.
why is everyone against the rear brake? i use it all the time. high speeds and low (depending on the situation). yes, i have locked up a few times but thats because i pressed it too hard and too quick. it can be difficult to manage but its good too know how to use it.
