Lights
Old Aug 14, 2009 | 04:51 PM
junker1244's Avatar
Default Lights
I know this is a common problem with the F4i's, but my headlights wont turn on. The running lights do, but I can't seem to get my headlights to stay on. I did a search on the problem and many have said that the ground wire needs re-soldered on the ignition switch. I just looked there and everything seems to have a solid connection. Anyone have any pic's of this wire so I can make sure that I am checking the correct one? Or can anyone else set me in a new direction?
Thanks.
Old Aug 14, 2009 | 05:04 PM
mike and ikes's Avatar
I haven't heard much on the subject so I don't think it is all that common of a problem. You might try taking off the front fairing but leave it dangling so you can wiggle connections. You might have a short in either the bulb connectors or in the wiring harness.
I beat Akin the net troll to a reply post!
Old Aug 14, 2009 | 09:10 PM
Aken's Avatar
July 2008 ROTM
And the point of this was...?
Old Aug 15, 2009 | 08:20 AM
snwbrdr435's Avatar
I had this problem and it was the left wire (The wire closest to the bike) in the ignition switch that looked ok at first glance but wasnt connected at all.
Old Aug 15, 2009 | 06:51 PM
junker1244's Avatar
Any where I can get a wiring diagram so I can see if we are referencing the same part or not.
xankriz
Apr 2, 2012 03:02 PM
fordfenatic09
May 17, 2011 10:40 AM
deerslider
Aug 24, 2009 08:23 PM
Ocelaris
Dec 7, 2006 02:14 PM
Moe Blike
Sep 12, 2006 12:40 PM
