License Plate Getting Bent with Hotbodies Undertail
Old Jul 17, 2009 | 08:31 AM
p8ntballn2's Avatar
Default License Plate Getting Bent with Hotbodies Undertail
Got a F4i about 3 months ago.. and i've been having problems with my license plate getting hit by the back tire.. and bending it up towards the front of the bike.. i've got the plate mounted pretty far up and away from tire.. but i guess not far enough.. does anyone know of a tag mount bracket that i can buy? so i can mount it right up under the lights.. its making me sooo mad.. My plate looks like its 10 years old now and been through WWIII and back. Thanks
Old Jul 17, 2009 | 08:46 AM
Jmclmorrow's Avatar
getting hit by your back tire...do you have it mounted on the battery box in front of the back tire?
Old Jul 17, 2009 | 10:53 AM
ibiggers's Avatar
I have mine mounted right behind the two lights, that way I didn't need to run another light to light my license plate. I bet its too low. I am 250 LBS and ride hard and have never touched my license plate. I'll look for a pic.
Old Jul 17, 2009 | 11:05 AM
__Z__'s Avatar
April 2011 Ride of the Month
lol gee man ru off roading with the thing or what? if its up towards the back of the bike idk how ur bottoming out your plate on your tire.....
Old Jul 18, 2009 | 04:02 AM
p8ntballn2's Avatar
It's pretty high up there I'll get a pic of it in a few hours and try to post it up here and no I'm not off roading
Old Jul 18, 2009 | 08:24 AM
__Z__'s Avatar
Do you ever notice your suspension moving up and down radically? I would say if so make your rear suspension harder.... there is no reason you should be hitting your plate.... def could use that pic
Old Jul 20, 2009 | 01:08 AM
p8ntballn2's Avatar
It's not so easy uploading from an iPhone hopefully tomorrow I can get something ip here I only way 175lbs my fat *** shouldn't be makin it squat that bad
Old Jul 20, 2009 | 01:16 AM
2H company's Avatar
It's not only about your weight. The suspension has to be tuned for every rider. There are two major things to worry about. First is preload and another is rebound. You should definitely check the rear suspension. Wrong set preload is probably the case, but can't tell you from here.
There was a great post on this forum about the suspension. As always can't find it when need to...
dupras2453
May 5, 2013 09:12 AM
jch82
Jan 19, 2012 08:18 AM
florida f4i
Jul 23, 2009 03:10 AM
6doubleohf3
How-To: Mechanical
May 1, 2009 01:59 AM
MellowYellow
Jun 26, 2006 01:36 PM
