Lego Caps
Old Apr 25, 2009 | 09:27 PM
mike and ikes's Avatar
Default Lego Caps
Ok, so I'm a nerd. So what? I think it looks cool 'specially with the white rim stripes. The bike is currently being painted white so the white Lego cap will fit right in.
Old Apr 26, 2009 | 01:35 PM
Berto's Avatar
This may not be a great idea. Here's why.
On my BMW RS a couple of years ago, I had a product called a Firefly. Basically, it's a little red LED pressure device that flashes with the tire pressure drops below the value it sensed when the device was installed. Clever idea.
Problem was, the Firefly was just heavy enough to cause the valve stem to start twisting in the rim opening. It was at a noticeable slant. The local dealer had seen these before and noted that as the twist continues, the stem starts to tear. Eventually, this could lead to a blow out.
The lego is probably not as heavy and may not cause this problem. But you should watch it carefully in case it does. If the stem starts to look slanted, get rid of it.
--Paul
Old Apr 26, 2009 | 01:46 PM
randyjoy's Avatar
Remember that the valve cap is one of the things that keeps air in. Does it have an actual sealing gasket inside of it or is it a real Lego block?
Old Apr 26, 2009 | 04:35 PM
Kevin48's Avatar
Not really a fan looks wise, but its your bike. If you like it keep it, it doesnt matter what we think. But I would definatly keep in mind what randy and berto said!
Old Apr 26, 2009 | 06:35 PM
It's a chrome valve cap imbedded into a lego piece. My old bullet caps were heavier! Shouldn't have any problems with weight.
Old Apr 26, 2009 | 07:23 PM
Aken's Avatar
July 2008 ROTM
Thanks for reminding me that my rear tire is missing a cap. *goes to put one on*
Old Apr 26, 2009 | 07:43 PM
randyjoy's Avatar
In that case...Go Lego!
Old Apr 27, 2009 | 12:24 AM
Zero1080's Avatar
I'm not a huge fan. Just me. i do want to see pics of the whole bike when it's done though.
Chad Brenno
Aug 23, 2013 09:13 AM
bmart
F2 For Sale / Trade / Wanted
Feb 16, 2011 07:09 PM
rrasco
Aug 7, 2006 02:54 PM
