Leaky brakes
When you replace the crush-rings, you'll need to bleed the system, as well.
Never hurts to replace the fluid completely. Something that should be done
every couple of years, anyway.
Might go ahead and pull the caliper of the mount and re-pack the hanger-pins.
Possibly polish up the pins the pads float on as well, they look a little corroded.
As Demon mentioned, check the pistons movement, also.
Push them in a bit and apply the brake to check they are moving freely.
Basically, this is a good excuse to go through the whole sub-system and
give it that 'minty-fresh' it probably needs.
Heck, when you get done, here...visit the front calipers, while the procedures
are still fresh in your mind.
Ern
Ern
Not great, but it gets the point across. I attempted to get a dial indicator on there, but between the exhaust being in the way and everything being aluminum, I had nothing to stick it to.
F4i Caliper movement - YouTube
Looks about normal to me.
That's not making the brakes stick. Maybe the rear master is being hung up by the pedal or the brake line is collapsed internally. If you can get it to stick again, crack the bleeder and see if there is pressure and if it releases. If there is, then it's a hydraulic issue. If not, it's mechanical.
