intergrated tail lights
Old Dec 14, 2006 | 03:26 AM
spidertron's Avatar
Default intergrated tail lights
hey guys, i jsut got a intergrated tail light for my f4i and it came with 2 resistors for the turn signal (im assuming) My question is that i also purchased a turn signal relay for LED, the relay was intended to slow down flashing rate of my front LED signal / old LED rear signal... Should i still install the resistor taht is provided extra from the tail light? or the relay will do the work of slowing the flash rate down
thanks
Old Dec 14, 2006 | 03:42 AM
gt2nv's Avatar
Default RE: intergrated tail lights
what is the value of the resisters?
Old Dec 14, 2006 | 04:46 AM
Blue Fox's Avatar
Retired Moderator
Nope, the Flasher is an electronic variable-load flasher that doesn't use current draw to "blink". Just need to install the flasher in place of the stock OEM one, and you should be set to go. If you already had the electronic flasher, just install the integrated signals and you're ready to go.
Old Dec 14, 2006 | 04:53 AM
spidertron's Avatar
awsome thankx for info
btw the resistor said 20W 5 Ohms with a R x 27 on top o.O
NonSense
May 23, 2011 11:32 AM
slipon
Jun 18, 2010 05:37 PM
peoples_champ
Jan 14, 2008 07:03 PM
mille
Feb 2, 2006 09:45 PM
muffinman
Jun 22, 2005 10:52 AM
