Installing frame sliders
Old Jan 2, 2017 | 05:10 PM
Jaybird180's Avatar
Default Installing frame sliders
It's been awhile since I did the last set so I'm seeking a bit of memory refresh on something. When I remove the bolt that mounts the engine to frame to install a slider, does the engine need to be supported to put the bolt back in place?
Thanks guys
Old Jan 2, 2017 | 07:52 PM
sjona2011's Avatar
as long as the rear mounts are in place you wont need to
Old Jan 2, 2017 | 10:13 PM
coalminer frank's Avatar
Dont do them both at the same time. Remove the 1st frame bolt & install the 1st frame slider then remove the 2nd frame bolt & install the 2nd frame slider. If you remove both at the same time it might drop just a coochy hair to much to allow installation of the new bolts without support from underneath.
Old Jan 3, 2017 | 08:55 AM
Jaybird180's Avatar
Thanks fellas. That's what I was hoping you'd say.
kiggy74
How-To: Mechanical
61
Sep 3, 2011 09:56 AM
cbrforum
May 8, 2006 06:43 PM
muffinman
Mar 27, 2006 10:34 PM
muffinman
Mar 27, 2006 10:29 PM
madsn11
Dec 10, 2005 08:13 PM
