Installing a CW fender kit...
Old Dec 18, 2011 | 10:47 AM
hondacbrgirl89's Avatar
Originally Posted by HellrazerinDC
Well there's your problem! You can't use a dog to chew down the parts for you!
LOL... yea she's good at that!
Old Dec 18, 2011 | 11:29 AM
So it's all done, I wouldn't recommend it to anyone unless you have patience. The reason why is because there instructions are not very clear nor are the pictures, but thanks to my buddies on here it was much clearer!!!!
Cutting is involved lol
In the end it looks really good, I like it. Don't plan on painting it, I think it looks good just stainless.
The key was a pain, had to drill the notch out a lil but more, the key mechanism would not go through
Old Dec 18, 2011 | 11:33 AM
Had to cut a space.....
So I had somewhere secure, and safe for my power commander!
Old Dec 18, 2011 | 11:43 AM
I have not put the bike back together because I'm working on my winter wish list , plus major cleaning in the process!
Integrated smoked tail light
1. Name:  smokedtaillights.jpg
OR
Integrated smoked tail light with the license plate LED light
SmokedFlush Mount Turn signals
2. Name:  flushmount.jpg
Smoked turn signals for the back!
3. Name:  turnsignals.jpg
4. Name:  windscreen.jpg
5. Name:  crashprotectors.jpg
Old Dec 18, 2011 | 12:08 PM
gotcbr's Avatar
Glad you got it together. First time I've heard of having to drill anything on the actual kit itself. Mine went together like a perfect puzzle. ;-)
In another thread about the CWFE, I remarked about the signal brackets. The kit comes w/ the larger brackets that are designed for the original factory signals or aftermarket smaller sigs. However, I called CW & asked if they had smaller brackets, which they do. I got them & installed them on my kit for my aftermarket signals. You can see the smaller signal brackets on my CW. I'm now using much smaller LED signals w/ those smaller brackets.
Old Dec 18, 2011 | 12:15 PM
Yea i'm glad it's together too....
So you have the hole where the key mechanism goes, in the hole there's like a slight notch there where on the key mechanism there is a piece on the side of it, the notches are suppose to match up. Well on the plate the notch was circular, on the key it was square. I hope that makes sense.
Old Dec 18, 2011 | 12:16 PM
gotcbr's Avatar
Looking at your other upgrade parts... I would also suggest the HotBodies LED front signals. They fit right into the detent of the bike's fairing. At their price-point they are good quality signals. Also, they can be wired to use as 2-wire-signal only or 3-wire signal & running lights.
Honda, 2001-03 CBR F4i, LED Blinkers, Hotbodies Racing
How-to here on forum to wire up as running lights as well...
https://cbrforum.com/forum/how-mecha...-inputs-84998/
Old Dec 18, 2011 | 12:18 PM
So if I buy a smaller set of turn signals, I can't use the brackets that came with it?
Old Dec 18, 2011 | 12:25 PM
gotcbr's Avatar
As I said above, you can use for either. However CW makes a pair of much smaller signal brackets specifically for small LEDs.
Old Dec 19, 2011 | 08:54 AM
HellrazerinDC's Avatar
I'd highly recommend the Proton flushmounts for the front signals! Love them on mine.
