insall on rear sets
Old Jan 17, 2008 | 08:47 PM
rodantking's Avatar
Default insall on rear sets
I'm putting on some used Vortex rear sets hear are my problems
1- The shifter linkage seam sort. I have the thing barley treaded in to get it to were I don't need to touch my toes to my knees on a up shift
2- Brake line is pulled as tight as you can pull it
3- Blrake line hits sub frame (looks like if I turn the banjo it will work but then I have to go get new washers )
4- where the cylinder links to the sets couldn't be any closer to hitting the clamps that keep the brake line out of the tire
any input would be appreciated
Old Jan 18, 2008 | 09:49 AM
Tahoe SC's Avatar
Default RE: insall on rear sets
pix?
1. how much did you get in on each side already? are you still using the stock linkage? the one with the set should be longer.
2. my brake line is tighter...
3. just loosen a bit and turn...no need for new washers. just make sure press the lever and don't let go as you do this so that pressure will force air out. you get little seepage but that's ok. then tighten bolt then let go of lever.
4. you can add some washers to get the clearance you need. sounds like it didn't come with any spacers, which it should.
Old Jan 18, 2008 | 06:46 PM
rodantking's Avatar
ORIGINAL: Tahoe SC
pix?
It's not the stock linkage. its in two turns
Old Jan 20, 2008 | 07:25 PM
rodantking's Avatar
Thanks for you input tahoe. Turned the banjo and put on a new chain and the brake lines has room to spare now both against the sub frame and on length
pr0jktmayhem
How-To: Mechanical
Feb 28, 2008 09:31 AM
brancart1
TRG Coating
Jan 5, 2006 03:26 PM
bowtiepwr
Jul 29, 2005 06:08 AM
