The Infamous FI Light Is On
Old 04-09-2007, 01:07 AM
F4iFreak's Avatar
Default The Infamous FI Light Is On
Got A '04 F4i And The FI Light Has Recently Come On. The Battery Was Junk And I Heard That Could Cause It So I Bought A New One And Its Still On. Ive Installed A Power Commander And Mapped It Up, Also Installed A BMC Filter And A Yoshi TRS. Ive Heard Some You Guys On Here Have Had It Blinking Or Solid. Mine Is On All The Time. Any Ideas? Thanks
Old 04-09-2007, 01:21 AM
Default RE: The Infamous FI Light Is On
does your bike run? check your battery connection! if all else fails kick it... j/k dont do that
Old 04-09-2007, 01:24 AM
F4iFreak's Avatar
Yea Its Runs. Had It Out Today For Alittle While. Connections Are Clean And Tight. Im Just Worried If Its Running Lean. Dont Need Tha Goin On.
Old 04-09-2007, 02:04 AM
I believe, correct me if I am wrong, but since the old battery was junk it may have caused the FI light to come on. Putting a new battery in was the right thing to do, but I think you still have to clear the memory of the ECM to erase the fault in the FI system. I don't have my manual with me right now but there is a way to get to code to find out what the error message was then you can also clear it. Does anyone have any info on it?
Old 04-09-2007, 02:58 AM
Shop Manual for f4i's.. it says the file is a movie.. but its actually a .pdf.... sneeky little buggers...
http://www.gofastvideo.com/gallery/i...hop-manual.htm
Old 04-09-2007, 11:08 AM
I dont have a power commander but I thought that if you did the FI light is always on. Correct me if im wrong
Old 04-09-2007, 11:45 AM
ADOLPH's Avatar
I HAVE A POWER COMMANDER ON MINE AND THE FI LIGHT DOESNT COME ON.
Old 04-09-2007, 12:25 PM
See how many times the FI light blinks while the bike is still on the kickstand. Once your raise the kickstand the FI light stays solid so as not to distract you. While riding turn your bike completely off and then on again (do it while at a red light) to see if the light still comes on. After finding out how many blinks check the manual and troubleshoot your problem.
And please turn your caps lock button off or stop capitalizing EVERY first letter. It gets really annoying and irksome to read.
jasonchristopher
04-19-2020 01:25 PM
jdub22
F2 Tech
05-16-2011 04:30 PM
jdub22
F2 Tech
05-11-2011 02:49 AM
NoLimitslja
07-21-2010 09:21 PM
mxmick03
11-29-2007 07:21 PM
Quick Reply: The Infamous FI Light Is On
