infamous "strange noise"
Old May 10, 2011 | 09:38 PM
jdub22's Avatar
Default infamous "strange noise"
So was riding my bike for awhile and then let it sit for like 20 minutes. Now when I start it and let it run there is a tick tick tick noise that speeds up with the engine from idle to 4000 rpm then you can't hear it. The person before me installed a manual cct. I hope this isn't the problem. Maybe it is just the valves working that is making the noise. What do you guys think?
Old May 10, 2011 | 10:59 PM
DagonRais's Avatar
Infamous double post.
But yes sounds like the cct sounds like you need to tighten it a bit
Old May 11, 2011 | 01:42 AM
9-5=4rr's Avatar
Easy job to do if that's the case .... let us know if that's what it is ... the walkthrough would take ya like 10 mins ... 30 max if you're bs'n with a friend and chuggin brewski's ...
Old May 11, 2011 | 04:23 AM
jdub22's Avatar
lol sorry about the double post the browser on my phone doesn't work very well. anyway how do I know if it is the cct do I have to take the engine apart. I don't know much about motorcycles only the fundamentals
Old May 11, 2011 | 04:51 AM
jdub22's Avatar
Ok so I watched a vid of someone adjusting their cct. They loosened the lock nut and turned the bolt counter clockwise until it was noisy they then turned the bolt clockwise until the noise was gone then they turned it a 1/4 turn more and tightend the locknut. So... if this is the problem then I will have results. I just got my bike out of the shop and he put in 3 valve shims. I don't think it would be the valves but I guess I will see later today
Old May 11, 2011 | 04:55 AM
9-5=4rr's Avatar
.... sounds like you're on top of things here man ... lol
Old May 14, 2011 | 07:35 AM
jdub22's Avatar
ok so do I do the adjustments with a warm or cold engine???
Old May 14, 2011 | 07:54 AM
9-5=4rr's Avatar
Warm
Old May 15, 2011 | 11:18 AM
jdub22's Avatar
so I tried adjusting it and I backed it out and I heard no change of noise twisted it in nothin I twisted it in until I could feel it start to vibrate and no change either way. So I twisted it out and tightened the lock nut and it makes a whine noise when I give it throttle. I backed it out some more and tightend it and it still whines. So I pretty much don't know if I messed up my cam chain or what I don't feel comfortable riding it in fear that I will mess something up. So now what?
Old May 16, 2011 | 04:30 PM
Bently600's Avatar
whine = too tight.
rattle = too loose.
if in doubt take it to the shop.
DON"T ride with the CCT super tight.... a little tight won't cause disaster but way over tight WILL cause disaster
crazytaxi
May 22, 2015 09:08 AM
Gnarly 928
Sep 7, 2013 07:52 PM
jdub22
F2 Tech
May 11, 2011 02:49 AM
KenG
CBR1000F For Sale / Found
Aug 9, 2009 05:20 AM
Cbr-norway
Jul 15, 2009 08:33 PM
