Idling Problems
RE: Idling Problems
Ok well i have been at work all day and i will start checking these things tomorow. I have found the plug that was in that picture. I can see that it is connected but i have not got the gas tank off yet so that i can check and make sure it is connected well.
I'm not exactly sure what you mean by "sitting up" but if you are talking about me not driving it much then.....I ride every day. Even when it was 20 outside i have been riding it at least to school and back
RE: Idling Problems
Ok i just got it all taken apart...i checked both the map sensor and whatever that electrical connection is in the picture
It is incredibly stange what is doing.....the FI light does not blink anymore.....but it still idles funny. sometimes it will be just fine and then ill rev the engine and then it starts idling so slow i think its going to die....this is really driving me crazy
RE: Idling Problems
it's the throttle position sensor. this may come a little late and i'm not sure about it either, but you may have been able to check it without removing the tank by looking at it from the underneath somehow.
Also i just took off my air filter and started it up without the air filter on there but my filter has some black stuff over on the left side of it. Could that be a problem.
RE: Idling Problems
o ok....well i checked that and it is connected good.....is it possible that i need a new throttle response sensor or a MAP sensor? Is there i way i can test to see if they are bad?
Also keep in mind that im a daily rider and it was working perfectly one day and then i was having these problems the next.
Thanks for all the help guys
RE: Idling Problems
well i fixed it finally...after 7 hours of working/reading. It was the map sensor after all.....all i did was disconnect it and blow it out with some compressed air and everything worked perfectly again.....i live in a really windy and dusty place so i guess it makes sense
thanks for all the help guys!
