I met the pavement!!
Old May 30, 2005 | 01:12 PM
CaronaBlack600's Avatar
Default I met the pavement!!
On May 26, 2005 I lost control of my 04 CBR600F4i and went down. The bike, and myself, are still in one peice.
there is damage to my front fairing, and left fairing, but the main issue is that the bike will not start.
The battery has juice and the fuses are still good. I did notice that when I put my key in and try to start, I dont hear the fuel injection motor.
If anyone can provide me with some helpful suggestions that would be great.
Thanks Guys
Corey
Old May 30, 2005 | 01:40 PM
homer319's Avatar
Default RE: I met the pavement!!
Man, I am not trying to make you feel stupid, but I saying this because I have done it myself. Check the kill switch. Like I said, I did it once myself and could not figure out why it would turn on but the FI would not kick in and it would not turn over.
Old May 30, 2005 | 01:48 PM
I just went out and checked the kill switch, still the same problems.
Old May 31, 2005 | 04:55 PM
f4ilapper's Avatar
Did you remove the front fairing and/or disconnect any of the electrical connections? The tip-over switch if disconnected or bent at an angle will also keep the fuel injectors from actuating. The tip of switch is right in the front under the nose of the front fairing between the steering head and headlights, it has arrows pointing up and "UP" labeld on it. I've screwed this up before to the point of running the battery down trying to get it started.
Rob
Cr250r67
Mar 16, 2010 10:19 PM
bradlb
Apr 22, 2008 11:07 PM
Upon1
Nov 23, 2007 01:33 AM
QuickNDeadly
Oct 6, 2007 10:05 AM
Beowolf150
Feb 9, 2007 07:51 AM
