I checked everything. I think
Was riding my 02 CBRF4i yesterday and when me and a friend stopped to get some gas for his bike i shut off but when i went to start up nothing nadda. So today i checked my fuses harrnesses angle sensor everything. The only thing i cant get is that i dont hear the fuel pump prime when i turn the key in the on position
help please
help please
Two things jump out right away 1) were you in gear with the kickstand down. 2) do you shut your bike off using the kill switch on the right grip. I've done number one on more occasions than I want two admit. If two then you may have worn out rocker switch.
ORIGINAL: Ruftags
dont worry, ive done 1 a few too many times as well...lol...it really got me confused the first time it happened. on my way bak from the dealer before i read the manual.
and will using the killswitch really wear it out in as little as four years? whenever i shut my bike off, i shut it off completely. the MSF course taught me to use the killswitch and the ignition everytime, so it has become habit...is it a bad thing?
My bike is an 01 and my switch isnt worn out...make sure you check stupid stuff like battery terminals and such.
________
Dodge zeo history
________
Dodge zeo history
Kickstand switch or wire may be bad, maybe fuel pump failed. Kickstand wire happenned to a buddies yamaha, I think when he was riding. good luck and try and post what it finally was.
well it was a loose wire under the soliniod switch i had that bike strip to the frame till i touched a wire that was clamped together but the clamp came open and the fuel pump kicked in was so happy but had to put the bike back together
