How to pull battery
Old Nov 13, 2012 | 04:47 PM
pookguy88's Avatar
Default How to pull battery
I have a 06 F4i... it says in the manual I have to disconnect the ECU before I remove the battery?!? Isn't it just like a car battery where I can just unplug it? How do I get that plastic shrouding off of it?
thanks!
Old Nov 13, 2012 | 06:38 PM
supersnake83's Avatar
The battery can be unplugged without disconnecting the ECU. The plastic cover can be unsnapped by pulling on the plastic pins. Then, disconnect the positive, negative and pull the battery up. For safety, I usually use electric tape and tape each terminal so they won't make contact with the metal frame or each other.
Good luck.
Old Nov 13, 2012 | 06:55 PM
gotcbr's Avatar
Originally Posted by supersnake83
... I usually use electric tape and tape each terminal so they won't make contact with the metal frame or each other...
Good tip there.
Old Nov 17, 2012 | 06:52 PM
Aken's Avatar
July 2008 ROTM
There's a hole under the battery to push up on it if you can't pull it up from the top, btw.
The manual probably recommends disconnecting the ECU because it sits directly on top of the battery. Just an ease of use thing.
Cro
Jul 28, 2008 12:05 PM
Nimbus87
May 8, 2008 11:02 PM
phishstyx
Jan 21, 2008 10:49 AM
Kingpat
Feb 19, 2007 02:36 PM
Kikepiz
Feb 9, 2007 06:46 PM
