how often are you supposed to change brake pads?
Old 03-25-2010 | 11:50 AM
musantemike's Avatar
Default how often are you supposed to change brake pads?
i have 03 f4i with 10,xxx miles. i ride pretty conservative, mostly highway and back road twisties. Im not to hard on the. I bought the bike with 4,xxx miles on it, and i would assume the pads had not been changed before that. As far as i can tell my brakes have good stopping power and dont seem to be fading. Is there a wear line on the pads or is it all about feel? what is the normal miles per pads usually?
Thanks
Mike (CT)
Old 03-25-2010 | 12:13 PM
ars1986's Avatar
yeah there is some what of a wear line that runs down the middle of the pad. what you can no longer see it. i would say change them, i always change them when i am doing anything that i have to take the tire off anyways. they are fairly cheap to replace and supper easy.
Old 03-25-2010 | 12:19 PM
__Z__'s Avatar
April 2011 Ride of the Month
+1 here... lol this is also why my build is taking so long... while i have everything apart i figured ide replace my chain as well as all my pads... fluids... etc... stuff ads up quick ha...
Old 03-25-2010 | 12:42 PM
drew0387's Avatar
how much do pads usually run?
Old 03-25-2010 | 12:59 PM
__Z__'s Avatar
depends on the brands but fronts since you need 4 pad usually run around 40 bucks rears around 20
Old 03-25-2010 | 01:09 PM
Junior2552's Avatar
Drew, get on motorcyclesuperstore.com or go to your local shop. It depends on the brands like Z said, but it also depends on the type of pads you get.
Old 03-25-2010 | 02:40 PM
drew0387's Avatar
what type of pads are you guys currently using?
Old 03-25-2010 | 02:43 PM
__Z__'s Avatar
idk what im using to be honest im using what came on the bike when i bought it from the prev. owner... so i hope some people get back to u so i too know what to order...
i have a feeling though its kind of all a personal preference...
and depends on the price you want to spend
Old 03-25-2010 | 03:24 PM
chuckbear's Avatar
EBC HH Sintered pads
Old 03-25-2010 | 07:48 PM
Zero1080's Avatar
I think I spent 70 dollars for both front and rear total? I replace mine when I have to noticeably squeeze the brake lever more.
Aheroicrevolt
08-26-2012 09:48 PM
portugal100
07-26-2012 09:20 AM
Anubis
How-To: Mechanical
07-07-2011 06:20 PM
eljrc16
05-20-2009 10:08 PM
Spieluhr
05-27-2008 11:10 PM
