How do I know When to change Brake pads?
Old 05-20-2009, 04:13 PM
Default How do I know When to change Brake pads?
When can I notice that I have to change the brake pads?
Old 05-20-2009, 04:59 PM
Look at the pads...seriously though take a look at how much friction material(pad) is left...if it is thin then replace em...
Old 05-20-2009, 05:09 PM
I think if you look in your owner's manual or in the mechanic guide that is available for the f4i; try to google it, or look around on this forum. It says that there are wear grooves on each brake pad, and if they are wore pass this groove (groove disappears) then its time to replace them. I'm pretty sure thats its right in the middle of the brake pad and runs horizontal. You should be able to see it without taking anything off the bike.
Old 05-20-2009, 09:08 PM
It's easier to see if you take the calipers off (takes one socket) and then you can check the wear groove (big groove in the middle). If there is no groove replace the pads other wise put the calipers back on and ride (don't forget to pump the brakes after you put the calipers back on).
Aheroicrevolt
08-26-2012 08:48 PM
portugal100
07-26-2012 08:20 AM
musantemike
03-25-2010 06:48 PM
Spieluhr
05-27-2008 10:10 PM
cyber00677
03-22-2008 03:10 PM
Quick Reply: How do I know When to change Brake pads?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
