How do I adjust headlight level? [+HID pics]
Old Nov 22, 2006 | 08:17 AM
ddaren's Avatar
Default How do I adjust headlight level? [+HID pics]
Hey guys... I just got my HID's installed for my low beams and high beams. .
For those who are curious... the brand is McCulloch, they're 6000K, H7's.
Well I love these lights, they're really bright and white. Maybe a little tinge of blue, but barely noticeable. Problem is that the low beam is shining out everywhere and aimed a bit high. It's blinding everyone.
Question is: how do I adjust the low beam height so it points more down? I wouldn't mind doing it for the high beam also to make it exactly like a low beam. I'd rather have 2 low beams instead of running 1 low beam at night only.
Diagrams would be useful.
Old Nov 22, 2006 | 10:26 AM
ddaren's Avatar
Default RE: How do I adjust headlight level? [+HID pics]
Okay I adjusted them myself.
I set the high beam to the lowest level.
For the low beam, I kept turning the screw and noticed the bulb start aiming down. I turned it so far it won't go any lower. How do I make it lower?
Old Nov 22, 2006 | 12:36 PM
Tahoe SC's Avatar
that's it...it's as low as it can go....it wont' go any lower...
the stock headlamp unit wasn't made for HIDs...so no matter how much you adjust, you're still going to have light going everywhere.
Old Nov 22, 2006 | 12:55 PM
95FD3S's Avatar
How much did you pay for the kit?
Old Nov 22, 2006 | 12:56 PM
Tahoe SC's Avatar
if he's the same dude from the other forum...$300 shipped...or could be unshipped...
Old Nov 23, 2006 | 02:22 AM
ddaren's Avatar
yeah i'm on cbrworld also. posted same stuff on there. noticed this forums is better and more active so i'll stick to this one.
and yeah, it was $300 shipped. Got a good deal on em. Usually they're $169.99x2 + $40S/H.
Old Nov 25, 2006 | 03:34 AM
Ocelaris's Avatar
Do you have some down the road or wall shots? Like this? How do you flash your high beams with a HID high beam ??? Did you compare a stock H7 bulb to your HID H7 kit?
The problem with most HIDs in Halogen reflectors is that 1) the bulb of a HID is an arc tube, and a halogen bulb is a filament (different size/shape) and 2) that they aren't even in the same spot, i.e. are too far forward or backwards to line up properly, like this pic explains:
Old Nov 25, 2006 | 03:38 AM
Ocelaris's Avatar
Try comparing where the filament and arc tube line up, maybe you can space your HID bulb back or forwards a tad to get it into the sweet spot...
Old Nov 25, 2006 | 04:54 PM
ddaren's Avatar
wow thanks for the info guys. didn't notice that about the bulb sizes... i'll definitely check it out.
and about the pics. I can take pics of my HIDs against a wall and on the road at night. But since I didn't take pics of my stock H7's (I should have... damnit!), I'll get on my friends bike and take a pic to at least compare how much brighter the light is.
Old Nov 26, 2006 | 12:25 AM
Ocelaris's Avatar
Pictures don't do a good job for determining brightness, because the camera adjusts to compensate... But a pattern is useful, to show if it's making use of the reflector correctly. Try moving the HID bulb bacwards and forwards and see if it changes the beam pattern, might just need to shim it back a tad.
(951) Baby Shortee
Jan 13, 2012 10:10 PM
inkredibleg
Aug 8, 2009 10:24 AM
Timmy_Jones
Oct 14, 2008 09:34 PM
Fat Boy
Jan 17, 2007 10:39 PM
ddaren
Nov 22, 2006 12:29 PM
