how to do an alignment on the handle bars, mainly the triple tree??????????????
Old Jun 27, 2010 | 11:42 PM
playb0i's Avatar
Default how to do an alignment on the handle bars, mainly the triple tree??????????????
as title says.
i notice my bike is not aligned. when i'm going freeway speeds and look down, the bike is facing toward left, but front wheel is slight right.
Old Jun 27, 2010 | 11:51 PM
kowen1208's Avatar
Should be pretty easy, I think, unless your forks/triple tree are twisted. Just loosen the handlebars where they attach to the triple and adjust.
Old Jun 28, 2010 | 08:05 AM
DBEAU's Avatar
https://cbrforum.com/forum/f4i-main-forum-11/how-align-your-forks-112703/
Old Jun 28, 2010 | 10:23 AM
randyjoy's Avatar
One easy method you can try that might re-align is to loosen the left axle pinch bolts, then with the front brake applied pump the forks up and down several times. Move forward slightly and repeat. Tighten the pinch bolts.
Since the forks are tubes within tubes that can rotate, loosening at the triple tree will not transfer to the axle alignment. When you take the wheel off, you can still turn the forks at the bottom, even with the triple tight.
jondecker83
Feb 2, 2012 03:11 AM
SEEYA7
Jan 8, 2011 09:18 PM
94_F2_KING
F2 Tech
Apr 30, 2010 10:22 AM
murtagh
Aug 28, 2008 03:37 PM
slimmyslim1420
Sep 23, 2007 04:19 AM
