how critical is changing coolant regularly?
Old Jun 25, 2009 | 10:05 AM
Rick619's Avatar
Default how critical is changing coolant regularly?
I've only got 16k miles on the bike and don't think the coolant has been changed before.
Can running old coolant damage anything if it never gets too hot and the fluid still looks clean???
I wasn't sure but i thought i heard something about it becoming corrosive after a while.
Thoughts? thanks
________
INTERRACIAL FRENCH
Old Jun 25, 2009 | 10:22 AM
nickels's Avatar
I Can't Sell On CBRF
Thoughts? thanks
if its not gettin hot then i wouldnt worry about it but new stuff is always better....i would put engine ice in it though if you got 35 bucks layin around...cooler temps make more HP and makes the engine last longer
Old Jun 25, 2009 | 11:50 AM
DBEAU's Avatar
You do realize that not everything on the back of the bottle is true right?
Old Jun 25, 2009 | 11:58 AM
nickels's Avatar
im assuming your talking bout the extra hp and longer lasting engine comment and yes those 2 things are very true....i didnt even read the back of the bottle to know that info is facts and i wasnt sayin it bcuz of the engine ice...its just plain facts no matter what you use
Old Jun 25, 2009 | 12:01 PM
gotcbr's Avatar
I would change it...easy project & gives peace of mind. Unless you're running the bike hard in harsh environments, you're *probably* ok but its just better to change it for fresh fluid.
I ride year-round & change mine every spring. Then again, I put on a lot of miles. ;-)
Old Jun 25, 2009 | 12:11 PM
Joey_f4i's Avatar
Is the original Engine Ice coolant for cars ok to use on motorbikes or is there a special kind of Engine Ice for bikes?
I'm a bit **** about using things ment for motorbikes, its a "ease of mind" kinda thing.
Anyone know?
Old Jun 25, 2009 | 12:45 PM
DBEAU's Avatar
Anyone know?
Just go to your Honda store and pick up some regular Honda bike coolant. It will work just fine and you can have your peace of mind too.
Old Jun 25, 2009 | 12:47 PM
DBEAU's Avatar
So you're saying that using Engine Ice rather than Honda coolant will yield more horsepower?
Old Jun 25, 2009 | 12:50 PM
Elfling's Avatar
Ladies Lounge Moderator
Anyone know?
I think it's the same coolant for whatever machine?
http://www.engineice.com/street_main.html
FWIW, the dirtbike/motocross guys I know here in Tampa swear by it, they say they wouldn't even think of running in the summer without it. They say you don't get the ridiculous temp drop the bottle claims you do, but it's enough to be noticeable.
Old Jun 25, 2009 | 12:56 PM
nickels's Avatar
there it is bigger so you can see it im sayin the engine has more HP and last longer if it runs around 200 instead of 225...not saying if you use a certain product it will do this and that but a cooler running engine (to a certain point of course) has more HP than a hot running engine
