how critical is changing coolant regularly?
I've only got 16k miles on the bike and don't think the coolant has been changed before.
Can running old coolant damage anything if it never gets too hot and the fluid still looks clean??? I wasn't sure but i thought i heard something about it becoming corrosive after a while. Thoughts? thanks ________ INTERRACIAL FRENCH |
Originally Posted by Rick619
(Post 802139)
Can running old coolant damage anything if it never gets too hot and the fluid still looks clean??? I wasn't sure but i thought i heard something about it becoming corrosive after a while. Thoughts? thanks if its not gettin hot then i wouldnt worry about it but new stuff is always better....i would put engine ice in it though if you got 35 bucks layin around...cooler temps make more HP and makes the engine last longer |
Originally Posted by nickels
(Post 802149)
Originally Posted by DBEAU
(Post 802180)
You do realize that not everything on the back of the bottle is true right?
im assuming your talking bout the extra hp and longer lasting engine comment and yes those 2 things are very true....i didnt even read the back of the bottle to know that info is facts and i wasnt sayin it bcuz of the engine ice...its just plain facts no matter what you use |
I would change it...easy project & gives peace of mind. Unless you're running the bike hard in harsh environments, you're *probably* ok but its just better to change it for fresh fluid.
I ride year-round & change mine every spring. Then again, I put on a lot of miles. ;-) |
Is the original Engine Ice coolant for cars ok to use on motorbikes or is there a special kind of Engine Ice for bikes?
I'm a bit anal about using things ment for motorbikes, its a "ease of mind" kinda thing. Anyone know? |
Originally Posted by Joey_f4i
(Post 802191)
(Post 802183)
(Post 802191)
I'm a bit anal about using things ment for motorbikes, its a "ease of mind" kinda thing. Anyone know? http://www.engineice.com/street_main.html FWIW, the dirtbike/motocross guys I know here in Tampa swear by it, they say they wouldn't even think of running in the summer without it. They say you don't get the ridiculous temp drop the bottle claims you do, but it's enough to be noticeable. |
(Post 802183)
(Post 802211)
So you're saying that using Engine Ice rather than Honda coolant will yield more horsepower?
there it is bigger so you can see it :icon_doh: im sayin the engine has more HP and last longer if it runs around 200 instead of 225...not saying if you use a certain product it will do this and that but a cooler running engine (to a certain point of course) has more HP than a hot running engine |
