Horn
Old Oct 24, 2007 | 06:29 PM
FozMan's Avatar
Default Horn
I bought my bike back in july, the horn never worked and i was excited to get a bike that i didnt really care that the horn didnt work, but after riding a few months, that horn would have came in handy a few times, my fuse still good, but i dont know exactly where the horn in located, is there anything i can do or can anyone tell me where to look to fix this?
Old Oct 24, 2007 | 06:35 PM
alekinci's Avatar
Default RE: Horn
you should be able to to see the horn from underneath the upper fairing. see if the the connector is secure and get a voltmeter and connect to leads to the harness. then press the horn button. if you get volts across that means that your horn is bad, if you dont get voltage that could be either bad wiring or the horn controller in the handle bar.
good luck
Old Oct 24, 2007 | 07:05 PM
FLYOU's Avatar
Default RE: Horn
sounds like a simple wiring issue. it's probably an easy fix... if you can find the source that is
Old Oct 25, 2007 | 12:07 AM
02cbrf4i4u's Avatar
Default RE: Horn
When ever I need to warn someone I just throttle it too redline...that usually lets everyone know im there and they shouldnt be!!!! But in all seriousness....it really does work when someone is coming into your lane....freakin dumbasses!!
odysseyzray
Jul 5, 2008 09:01 AM
Tacoma25
May 27, 2008 09:32 PM
buckd44
Apr 17, 2008 05:20 AM
FosmoenAlex
Apr 10, 2008 08:26 PM
