High idle RPM
Old 02-22-2010 | 12:00 PM
2H company's Avatar
Default High idle RPM
Hey guys!
I'm seeking for your knowledge and experience here. My buddy and I recently performed valve clearance check and spark plugs swap. This was quite "fun". Had to get through the tank, throttle body and valve cover.
This took us for some time to finish and the time was really late when we were putting everything together. The first thing I noticed after going first a couple of yards is that my idle is at 3k RPM at all times and keeps fluctuating. The next day I adjusted this by the idle **** (thank god we noticed it hanging in the inside of everything and were smart enough to wire it outside). Now I have my 1.3k idle speed.
The only funky thing, and the one I don't like the most, is the warm up idle, which now always goes up to 3.5k.
What could cause this in your opinion? Wrong pressure on CCT chain? Timing? Or maybe throttle body problem? It's difficult to explain, but I think I also feel some additional vibration at low RPM and noises. This might have been always there though... What's your guys opinion?
Old 02-22-2010 | 12:09 PM
speedyf4i's Avatar
my bike always idles at around 3k on cold start, but it goes down as it warms up...isnt this normal?
Old 02-22-2010 | 01:14 PM
vangill's Avatar
July 2010 ROTM
mine does the same i thought it was normal too
Old 02-22-2010 | 02:04 PM
Bently600's Avatar
it is normal.
Old 02-22-2010 | 04:31 PM
2H company's Avatar
Hmmm, my bike used to stay at 2.5k before... I'm prolly overthinking everything again in pursue of perfection.
Thanks for the replies guys!
Old 02-22-2010 | 04:51 PM
letsride's Avatar
3k idle is quite normal,and as soon as you see the numbers on your temp. guage the rpms will come down to almost idle around 130*
Old 02-22-2010 | 05:35 PM
james_hale2's Avatar
3k is nomal like he said. and now that you played with everything, if you didnt unhook your battery, your computer is releaning everything. if you're not hearing whining like a turbo your chain aint to tight. as far as the extra 500 rpms durring warm up see if its still there at the end of the week.
ebag600
10-06-2020 02:08 PM
SPR-GRN
05-07-2012 06:08 PM
cbr saw
F2 Tech
05-28-2010 08:58 PM
MrGoats
01-23-2010 08:41 PM
crazycanasian
12-21-2009 08:16 PM
Quick Reply: High idle RPM
