High beam adjustment
Old Jul 30, 2006 | 12:58 PM
kevntri's Avatar
Default High beam adjustment
How do I lower the angle of the high beam?
I tried the phillips screw and it didn't do aanything?
can someone describe the procedure?
Thanks
Old Jul 30, 2006 | 04:00 PM
Indasoul's Avatar
Default RE: High beam adjustment
Phillips screw didn't do anything??? the assembly may be stuck/dry and not be moving...
according to the service manual (01-03), vertical adjustments are done simply by turning the screw (clockwise turn to aim upwards),
and horizontal adjustments made the same way (differnet screw of course). may be different for your 2005.
??? make sure you're turning the right screw!
Old Aug 1, 2006 | 02:06 AM
raredogg's Avatar
the vertical adjustment in located where the air intake cover is. There is a hole on both sides. I have a 05 too great bike.
buknoy
Jul 1, 2009 06:18 PM
justasquid
Oct 7, 2008 03:21 AM
jerbear
Aug 29, 2008 08:52 AM
ddaren
Nov 26, 2006 07:02 PM
stephen4785
Mar 9, 2005 09:38 PM
