HID Question.
Old Dec 5, 2007 | 06:12 PM
inkredibleg's Avatar
Default HID Question.
Can you re-wire our headlights to have them both on all the time. Cause I was thinking of getting an hid kit but I wanted both to work as low-beams instead of low and high.
Old Dec 5, 2007 | 06:18 PM
dwschultzy's Avatar
Default RE: HID Question.
I did it. I just used the power and ground wire from my high beam switch to activate the power for the balast's. You will want to re-position your high beam so it doesnt blind on coming traffic. Keep in mind the reflector housing that projects the beam is different on the high beam side. This will make it always look like a high beam. You will definetly want to adjust the beam down, or you will be blinding your on-coming traffic.
Old Dec 5, 2007 | 06:32 PM
From what I understand they are both the same bulb size right ? if so then what makes one bulb shine brighter than the other ?
Old Dec 5, 2007 | 07:19 PM
socalninja's Avatar
It doesn't shine brighter, it's just that the reflector housing directs the light to a higher angle than the low-beam.
Old Dec 6, 2007 | 10:29 AM
muckdawg24's Avatar
You could save some money and get Silverstar bulbs and lower your high beam and keep your high beam on all the time. That's what I did. $30 and I'm done. Way brighter than stock.
Old Dec 6, 2007 | 10:24 PM
How can you move the headlightup or down ?
Old Dec 7, 2007 | 01:33 PM
muckdawg24's Avatar
ORIGINAL: inkredibleg
There is an adjustment screw(s) on either side. one for horizontal, one for vertical.
Old Dec 7, 2007 | 08:51 PM
Blue Fox's Avatar
Retired Moderator
ORIGINAL: dwschultzy
I'm confused. You have two ballasts right? 1 ballast connected to the low beam wire and 1 ballast to the high beam wire. Is this how you did it, or did you do something differently?
And yes, both high beam and low beam are the exact same bulb, exact same wattage. The reflector is different for the high beam side. It scatters light up and around versus the low beam keeping it low and wide in a line pattern. It just "appears" the high beam is brighter because of the way the reflector works.
And you should have an adjusting screw to adjust the beam angles for both high and low beams.
HID's are such a vast improvement over stock bulbs, you don't need the high beams on at night. Just adjust your low beam up (just a little). Save the high beam for highway speeds and daytime use.
And no offense, but Silverstars are garbage. They're actually less-bright than stock bulbs, because the light has to pass through their "whitening" filter. They're a tad whiter than stock (which may seem like their brighter.) but in lumens, they're actually less-bright, so don't let the marketing fool you. HID's are the way to go (ESPECIALLY since kits are hovering around the $80 mark)
I did extensive research into HID systems, and have installed many kits. 1 on my bike, 1 on my roommates bike, 1 on my other roommates bike, 1 in my car, 2 in my parents cars, 5 in other peoples cars. Each said there was a VAST improvement in visibility.
I did a short write up on how to install them into a 600RR. You can take the same basic knowledge and apply it to any bike though...........
https://cbrforum.com/m_379249/tm.htm
Old Dec 7, 2007 | 09:17 PM
halik008's Avatar
ORIGINAL: Blue Fox
all HID's without HID projectors are good for are getting you tickets. HID's are not designed to work with regular halogen reflector bows and the light HID's produced is scattered all over rather then reflected in a single directions like it is w/ the projectors. It blinds everybody no matter what you try to do and will get you tickets
Old Dec 7, 2007 | 09:52 PM
dwschultzy's Avatar
ORIGINAL: Blue Fox
Yes I have two ballast's. I power both of them using the high beam wire. This way I can have them on or off. The light reflection is not better in my opinion. I did it before any extensive research. I am currently looking into a projector mod. I am thinking of using the "tsx" projector.
As it does project a different light. It does not project it far enough to be considered better in my opinion. All hid's are designed to be used with a projector rather than a reflector.
