Hid lights
Old Jan 13, 2014 | 08:26 PM
Nlabella29's Avatar
Registered Users
Default Hid lights
Hey all
I have an 01 Honda cbr f4i. My main light is currently a blue HID. If I wanted to replace the bulb with a bright white bulb. Can I do that or do I have to buy a completely different kit? I would also like to replace my high beam as well. Again, can I go as simple as a bulb replacement or do I need a kit? If anyone could get back to me. I would really appreciate it...
Nick
Old Jan 13, 2014 | 09:58 PM
RudyGT's Avatar
so what bulbs do you have in your bike? do you have a blue tinted halogen or do you have an arc lamp type with a ballast, that burns so bright it is in the blue spectrum?
you can buy replacement HID's that would be lower color temperatures. i think your first order of business is to see if you have HID's or the stock h7 halogens.
Old Jan 14, 2014 | 09:17 AM
CorruptFile's Avatar
June 2013 ROTM
You can buy just a 4300K bulb or something and that will give you a more white color, but if you want to change your hi beam as well, you should just buy a 'car' kit with 2 bulbs/ballasts. Save the extra ballast in case one fails on you.
Old Jan 14, 2014 | 08:11 PM
Nlabella29's Avatar
Registered Users
I don't know if this helps at all.
This is my main light. It has a ballast
Old Jan 14, 2014 | 08:15 PM
Nlabella29's Avatar
Registered Users
Where's a good place to get bulbs?
Old Jan 15, 2014 | 05:45 AM
Nlabella29's Avatar
Registered Users
This light has a ballast not the one posted already.
Old Jan 15, 2014 | 06:42 AM
jeffjones's Avatar
The main bulb in that picture is not an HID, It is a halogen.
The bulb peeking out from the left is an HID bulb.
Old Jan 15, 2014 | 09:37 AM
June 2013 ROTM
ebay.
Old Jan 15, 2014 | 02:50 PM
Nlabella29's Avatar
Registered Users
The HID has 2 wires with harnesses coming out from it. Would I need to buy the bulb with wires and harnesses attached? Or can that bulb be changed out...
Old Jan 15, 2014 | 03:47 PM
June 2013 ROTM
You need a bulb with the wires. Those bulbs usually aren't removable. And that bulb has to have the same connectors as your current ballast (unless you want to cut/resolder).
xankriz
Apr 2, 2012 03:02 PM
fordfenatic09
May 17, 2011 10:40 AM
deerslider
Aug 24, 2009 08:23 PM
Ocelaris
Dec 7, 2006 02:14 PM
Moe Blike
Sep 12, 2006 12:40 PM
