HID headlights
Old Aug 12, 2007 | 09:06 PM
  #21
jutsin's Avatar
Default RE: HID headlights
Don't forget to change the headlight fuse. The stock 10A just can't handle the draw from the ballasts and it'll blow the instant you turn the high beams on
I didn't....doesn't sound like a good idea to me to just throw a bigger fuse in something not made to draw more than 10 amps.... Mine has been on since April or May and I haven't blown any fuses.
If you do have an issue with the fuse blowing it would probably be a better idea to install a couple relays to draw directly from your battery for either light so you don't burn anything up.
Old Aug 12, 2007 | 09:22 PM
  #22
Daemian's Avatar
here is what i did
https://cbrforum.com/m_348346/tm.htm
my fuse blows if i have the highs on when i turn on the bike key, if i let the lows warm up then switch to highs (about 1 minute which is less than i let the bike warm up to 130 degrees anyways) then i have no problems. just make sure its on low before you turn the key and always have a spare fuse incase and keep a 10mm screwdriver handle socket to get under the seat...
Old Aug 13, 2007 | 08:17 AM
  #23
ddaren's Avatar
These are McCulloch's 6000K. Slight hint of blue compared to others
Old Aug 13, 2007 | 12:35 PM
  #24
DThompson's Avatar
My buddy bought a Triumph 675 a little while back and the first thing he did was put some spare HID's on it. They look great and were cheaper than normal price
Hes from Calli and hes Asian so hes got the hook up.
Old Nov 5, 2008 | 05:01 PM
  #25
Pootie Tang's Avatar
anyone else experienced McCulloch HIDs? I have read bad things about that brand. If McCullochis not good then wut brands are good?
Old Nov 5, 2008 | 05:31 PM
  #26
CBR Time's Avatar
Just a note on the silverstars buring out etc, i remember my old GTI i had changed just bulbs to silverstars , def a brighter bulb but as mentioned they dont seem to last very long? burns @ a hotter temp is my guess, filiment cant handle this over time and burns out? im not a night rider lol, so as much as id like HID's ill prob just opt for the silverstars or comparable bulb replacment. If i find they start burning out every few months, i may just bite the bullet and get some HID's.
Old Nov 5, 2008 | 05:41 PM
  #27
Stephens's Avatar
https://cbrforum.com/m_379249/tm.htm
Heres a write up that might help
Old Nov 5, 2008 | 11:32 PM
  #28
Xuracing's Avatar
Here are mine, 8000k
Halogen on the Left HID right
danroonie
Dec 8, 2011 02:42 PM
OneWheel929
Jul 5, 2011 05:25 PM
cptspiller
Jun 2, 2007 03:44 PM
1000rrrider
May 6, 2007 07:58 PM
steve00ses
Aug 10, 2006 08:06 PM
