Help with the Tach.
Old May 22, 2006 | 06:39 PM
Sprocket360's Avatar
Default Help with the Tach.
I didn't get any responses in the general tech section so i thought i might ask the f4i enthusiasts, any direction would be helpful. Thank you.
Anyone have any ideas why the tach on my 2002 f4i stopped working? I checked for loose connections in the back of the gauge cluster, as well as for blown fuses. I was looking at other posts for the same issue only found one that said to check the connections... When i turn the bike on the tach does the up and down sweep through the rpms(mph, clock, and lights work fine). I hate not being able to see the rpms.. Any help would be appreciated. Thanks in advance.
Old May 22, 2006 | 07:54 PM
dwhite645's Avatar
Default RE: Help with the Tach.
Sounds like the sensor where it get's the info from the engine, since it goes up and back to zero when you turn the key on.
Old May 22, 2006 | 09:45 PM
would you happen to know if this is a replaceable sensor or part of the ecu? I have the service manual I have no idea what that would be called. Thank you.
Old May 23, 2006 | 01:06 AM
Indasoul's Avatar
Hey, who needs the tach??
Just listen to the sound of the eingine... that'll tell ya!
j/k
I'm sure you've already done this...but just to make sure:
Doesn't the service manual have the info about what the connectors are, and where they're located?
Check page 19-13. (also refer to 19-11, 19-8).
Old Jun 18, 2006 | 07:51 PM
gfiend's Avatar
I am working on a 01 f4i and I am having the same problem. anyone have any answers yet?
Old Jun 21, 2006 | 03:16 PM
I replaced the guages and there was no difference. Iincidentally I now have a working set of gauges with 4600 miles on them for sale... just send me an email. The next step is to replace the ECM.... If that doesn't work I guess ill have to take it to the shop.
Old Jun 21, 2006 | 08:48 PM
alekinci's Avatar
Did you drop the bike or replace the battery recently? Just curious?
Old Jun 22, 2006 | 11:11 AM
I replaced the battery recently, but it hasnt worked since I bought it. It could have been dropped.
Old Jun 22, 2006 | 11:48 AM
alekinci's Avatar
Well I was just thinking that if the connection is good where the computer is. Its right on top of the battery, that platic box. it might have become loose if the previous owner was messing around with it. Thats all i got on this matter, sorry i can help more
Old Apr 12, 2012 | 09:44 PM
Austin55cbrf4i's Avatar
My tach does the same thing. Wtf is wrong with it?
hamlin6
Oct 24, 2014 10:57 AM
DagonRais
F2 Tech
Apr 25, 2011 07:15 PM
R Dub
Aug 27, 2010 09:52 AM
clepies
Apr 10, 2010 02:55 PM
tlhawkes
Dec 15, 2009 08:13 PM
