help a noob
Old Mar 21, 2011 | 02:15 PM
CodyJ28's Avatar
Default help a noob
Where is the speed sensor located? Trying to hook up my 12 o clock speed healer
Old Mar 21, 2011 | 02:19 PM
nickp123's Avatar
errr i think its under your seat if you look above the shock...not 100% sure on that
Old Mar 21, 2011 | 03:16 PM
heyitsmelam's Avatar
waaaay down there...probably the hardest thing to get to. ever.
Old Mar 21, 2011 | 03:37 PM
Aken's Avatar
July 2008 ROTM
Yeah, it's above the transmission, below the rear shock. When accessing mine, I had to remove the top two bolts of the subframe, tilt it down, and then remove the coolant overflow container. Some people might not have to do quite that much work, depending on where the plug is for you.
Old Mar 21, 2011 | 04:12 PM
CodyJ28's Avatar
So whats the best way to get to it lol
Old Mar 21, 2011 | 04:14 PM
CodyJ28's Avatar
Just read ur post aken guess ill have to do it after work thanks a lot guys
Old Mar 21, 2011 | 04:23 PM
CodyJ28's Avatar
Old Mar 21, 2011 | 05:02 PM
iJapanesey's Avatar
Easiest and fastest way to take it out is to use 3 extensions on your ratchet, with a 10mm. You'll need to lift your tank(no need to take it off completely). It's a tight squeeze, but better than doing it the manual way(taking off throttle bodies) or doing it Aken's way.
Old Mar 21, 2011 | 10:39 PM
Aken's Avatar
July 2008 ROTM
He just needs to get to the plug, not to remove the sensor itself. Ratchet won't do much good in that situation.
Old Mar 22, 2011 | 11:47 AM
CodyJ28's Avatar
yep this is what i need to do...i need my little nephew here with his little hands/skinny arms lol
Ale Golem
Aug 5, 2013 12:28 PM
CBRtech707
Sep 2, 2009 04:12 PM
Vanandt71
Jul 29, 2009 07:40 PM
reorx911
May 20, 2007 01:52 PM
SchiraF4I
Feb 10, 2007 11:52 AM
