help a noob
Where is the speed sensor located? Trying to hook up my 12 o clock speed healer
errr i think its under your seat if you look above the shock...not 100% sure on that
http://i624.photobucket.com/albums/t...418/pic_04.jpg
waaaay down there...probably the hardest thing to get to. ever. |
Yeah, it's above the transmission, below the rear shock. When accessing mine, I had to remove the top two bolts of the subframe, tilt it down, and then remove the coolant overflow container. Some people might not have to do quite that much work, depending on where the plug is for you.
So whats the best way to get to it lol
Just read ur post aken guess ill have to do it after work thanks a lot guys
Easiest and fastest way to take it out is to use 3 extensions on your ratchet, with a 10mm. You'll need to lift your tank(no need to take it off completely). It's a tight squeeze, but better than doing it the manual way(taking off throttle bodies) or doing it Aken's way. |
Originally Posted by iJapanesey
(Post 1028514)
Originally Posted by Aken
(Post 1028680)
He just needs to get to the plug, not to remove the sensor itself. Ratchet won't do much good in that situation.
