Help! Bikes not holding a charge
Old Apr 23, 2013 | 03:30 PM
JonezyWyo's Avatar
Default Help! Bikes not holding a charge
I went to go for a ride the other day and the battery was completely dead. I jumped it and rode it for about 10 minutes and stopped to talk to a buddy. When I tried to start the bike to leave, it was completely dead again so I jumped it again to get it home, only this time the bike would bog down and barely made it home. I haven't had a chance to pick up a manual yet and between work and classes I really don't have any time so I've been thinking about just taking it to a shop, but I thought I would check with you guys first to see if you had any ideas.
If I can get the bike to start (jump start) it will idle for awhile and will throttle up but then lose rpms and die.
TIA guys!
Old Apr 23, 2013 | 08:11 PM
svek's Avatar
Most likely a bad rectifier or bad battery.
If you want to figure it out yourself, get a multimeter and go follow the steps on this chart
http://www.electrosport.com/technica...ng-diagram.pdf
Old Apr 25, 2013 | 04:21 AM
mnazary's Avatar
This. Hopefully it's just the battery. Much cheaper to replace.
Old May 2, 2013 | 06:51 PM
JonezyWyo's Avatar
Hey guys, I have the battery charging to test it and the rectifier. Right now I'm replacing the stator cover gasket, just wondering if there's anything special I need to do first. I also wanted to ask what kind of oil you are running. Thanks!
Old May 4, 2013 | 04:10 PM
F4iMane's Avatar
Arrow
I agree but this is only part of the charging system, also could be the stator. So consider the battery, rectifer, stator.
if it is some type of uncommon wiring problem that could take alot of money to figure out
hope that helps you.
Old May 5, 2013 | 06:34 PM
F4iMane's Avatar
no updates yet? Good luck with that then.
matt56us
Nov 23, 2011 02:12 PM
khangkou
Mar 25, 2011 08:46 AM
khangkou
Apr 29, 2009 07:34 PM
IwannaCBR
Apr 23, 2007 10:53 PM
Versatilx1
Apr 6, 2006 03:57 PM
