Help! Air filter install
Old Dec 20, 2012 | 05:48 PM
totoy_mola's Avatar
Default Help! Air filter install
Hello guys,I am installing a new air filter and I just want to make sure I'm doin it right. Does this rubber circled in red go into that metal pipe? Just wanna make sure. Thanks!
Old Dec 20, 2012 | 06:41 PM
McBreezyF4i's Avatar
Yea I think so. Its one of the tubes that come out the bottom by ur clutch pedal
Old Dec 20, 2012 | 06:59 PM
totoy_mola's Avatar
Yah I pulled the tank up and didn't noticed if it was attached to that pipe or not.
Old Dec 20, 2012 | 10:09 PM
stlcbr600f4_newb's Avatar
yes it does connect there... that tube has no give to it and comes off every time you lift the tank... if difficult to reconnect set the front of the tank down lift the back and there you go...should be able to get it slipped on with out a problem
Old Dec 20, 2012 | 11:15 PM
totoy_mola's Avatar
Thank you so much guys. Is that what they call the air/breather tube or the overflow tube?
Old Dec 21, 2012 | 01:28 AM
fuel tank vent hose the larger one is the overflow
kingtut
F2 Tech
Aug 4, 2013 02:41 AM
The__Rider
Aug 12, 2009 11:14 AM
Wolfman707
Apr 15, 2008 09:03 PM
TennesseeCBRF2
Sep 12, 2006 12:38 AM
Pablo
May 24, 2005 01:29 AM
