HELP!!!! 1.5 quarts of FUEL in the oil
I just bought this 02 f4i a month ago abd recently have Been having engine trouble lately..white exhaust...once the bike was warm it wouldnt idle... so I decided to start going through my bike. Spark plugs were fine. Throttle bodies were pretty caked so I cleaned those and airfilter is fairly new.. put bike back together started up to run to the store... and blue smoke started puking out.. this is new to my bike...I shut it off and pulled the tank back off to check connections etc.... noticed that( from my knowledge) the FPR had a golf t on one side.... was looking up that issue as i decided to change the motor oil.. whrn i got the bike it was a little low... added a little so it was betwrrn the lines... when i drained the oil it reaked of gasoline and when it wad done draining and i removed the oil filtet...there was 5.5 QUARTS OF OIL AND GASOLINE.....FML PLEASEEE HELP ME OUT
A google search can yield a lot of info. I found this.. it might help you some. Good luck!
Gas in oil problem..again.. - Honda Motorcycles - FireBlades.org
I don't know what the "bump" thing is...
I have done Google search but it's hard to read every thing just using my cell phone. But thank you for the link...
And I don't know why but the previous owner has one side of the fpr plugged... the side that points to the right side of the home... I won't be running it until I find the problem
if you bought it like that i would punch the PO in the face, repeatedly. The the fpr is how the fuel is put into the engine and returned. The side that was blocked was obviously the return to the fuel tank that wasnt used somehow worked its way into the crankcase(my guess). First make sure the FPR is hooked to both the intake and return lines. change the oil and start it and pray. i dont know what kind of damage gas in the oil can do but i know that a 2 quart overfilled oil pan will cause damage from being that full alone. best of luck man
Depends how long/hard it was run like that and how much fuel was in there.
The fuel thins the oil. Everything will wear down faster. Main/rod bearings, piston rings, lifters, etc. Ever hear about people tuning their motors for a high perf. build and then having a spun bearing or rings won't seat, etc. Usually because they're dumping gas right off the bat during tuning and they never change the oil a million times like they're supposed to.
After fixing the problem I would do a dry/wet compression check to make sure everything is decently okay with the bottom end and I would run thinnest oil possible for a little while, as well as changing it like after like 100/200 miles to make sure all is okay. I would also make sure the engine gets up to operating temp and take it easy until I know things are good for sure.
Oh yeah and I forgot about the tranny...I have no idea what this means for it or your clutch but once again be wary.
Bryantsito
03-25-2012 02:40 PM
