Got my frame sliders on... took lots of pics
I figured, what the hell, might as well take some pics along the install process... so I did!
Got them on tonight, along with my new left side fairing. I was gonna do the stator cover too, but it's gonna leak oil when I take it off and I don't have any more oil to add at the moment, so I'm just gonna wait until next weekend when I do my oil change. I'm actually kinda disappointed in how they came out... my hole drilling skillz SUCK!!! Neither of them are centered in the hole at all. The right side isn't quite as bad, but the left side is horrible! It's actually rubbing on the front edge of the fairing, so I might have to do a lil trimming to make them fit a little better
Anyways, here's how I did them... start to finish
Laser pointer.... my centering apparatus of choice, lol
Center it right on the engine bolt to be removed and replaced with the slider bolt
Mark the fairing
I put some tape around the surrounding areas "just in case" of a slip of the drill, and to help hold the edges of the stickers together while drilling. I also drilled a small pilot hole to make sure it went in exactly at the right spot without moving
1-7/8 in hole saw
I cringed... having to do this to my brand new fairing right out of the box
Came out beautiful!
Engine bolt out
Frame slider in
Nice and tight
Finished... right side
After cleaning all my greasy fingerprints off
Put the brand new fairing on the left side
So now I just gotta do the stator cover, and get the tail and front repainted and she'll be good as new again!
Got them on tonight, along with my new left side fairing. I was gonna do the stator cover too, but it's gonna leak oil when I take it off and I don't have any more oil to add at the moment, so I'm just gonna wait until next weekend when I do my oil change. I'm actually kinda disappointed in how they came out... my hole drilling skillz SUCK!!! Neither of them are centered in the hole at all. The right side isn't quite as bad, but the left side is horrible! It's actually rubbing on the front edge of the fairing, so I might have to do a lil trimming to make them fit a little betterAnyways, here's how I did them... start to finish
Mark the fairing
1-7/8 in hole saw
Came out beautiful!
Engine bolt out
Frame slider in
Nice and tight
Looks good buddy. Glad to see your getting her back together. My vortex sliders have been sitting an my work bench for about 2 months now. Just got to get up the nerve to cut my fairings.
Jared -
Great job!
You are the only one who will notice that the sliders aren't exactly centered in the holes. Trust me on this.
If you really can't stand it, get some small diameter black rubber hose (like vacuum tubing) and split it open along its length. Then slide the tubing over the edge of the cuts you made for the slider - instant and easy grommet on the inside of the slider hole that will hide anything.
Great job!
Good job using the lazer beam method.
Clean cut, dead on center. SWEET!!!
EPNF4i "Just do it!"
I put mine on as soonthey came in. I would have kicked myself in the@$$ if somethingbad happend and never got around to putting them on.
EDIT:
Looked close enough to me. lol
EDIT:
try adding these trim pieces to clean it up a bit if u like. got em from ace hardware
http://www.putfile.com/imnorman/images/111404
good stuff. i have the same thing going o my left side fairing. the plastic is rubbing off the slider. i think its because the bike is tilled to the left side during the drilling process. if anyone plans to do this i strongly recommend doing this on a stand or have a friend level the bike.
