getting ready to install slip on.
Old Apr 9, 2007 | 01:36 AM
chpsk8er630's Avatar
Default getting ready to install slip on.
When trying to install a slip on... Should I try to get the gasket out of the stock exhaust or just use some high temperature sealant? I think this would be easier to do... anyone do this?
Old Apr 9, 2007 | 01:40 PM
Tahoe SC's Avatar
Default RE: getting ready to install slip on.
new pipe won't fit over the stock gasket.
should fit snugly over midpipe. if you are worried about leaks, then use some high temp RTV.
Old Apr 9, 2007 | 01:46 PM
amnesia's Avatar
With an Akra, I didn't need the gasket or RTV. I put a bit of ceramic anti-seize on so I could get it off easily down the line.
Old Apr 10, 2007 | 05:27 AM
snobrdrdan's Avatar
Yup....didn't need the stock gasket with my Yoshi pipe either (or with the Micron I had before it either).....in fact, they tell you not to use it
It wouldn't fit anyways
Old Apr 13, 2007 | 05:49 AM
Big Gaz's Avatar
You won't need it. the slip on pipe width is only slightly bigger than the header pipe. When you fit it up make sure the header clamp thats supplied covers the slots in the mid pipe and it shouldn't leak.
G
Old May 13, 2007 | 01:04 PM
ijano's Avatar
ORIGINAL: amnesia
hey bro, a question for u..do u see any diff with ur temp after installing akra? i mean with the silencer still intact..coz i just fixed mine with akra and there seems to b a lot of diff in the temp...with and w/o the silencer..
mmgsport
Mar 27, 2008 06:01 AM
codybaxter
Mar 5, 2007 03:55 PM
So Cal
Aug 3, 2006 03:27 PM
woogie
May 24, 2006 11:13 PM
Wellsy04
Apr 17, 2006 08:34 PM
