getting past neutral
Old Mar 30, 2006 | 01:38 PM
DThompson's Avatar
Default RE: getting past neutral
The Batwing
they should just make all bikes automatic
J/k
That would be crazy. Imagine if you were in a wheelie and the bike shifted to the next gear on its own before you were ready for it.
Could be devistatingly bad.
Old Mar 30, 2006 | 03:22 PM
F4iGuy33's Avatar
I have an 01' F4i and it does the same thing i thought my transmission was going then a buddy of mine told me i have to shift kind of hard to 2nd so i dont get stuck inbetween so thats probably the problem just try shifting harder.
Old Mar 30, 2006 | 05:29 PM
stinger95's Avatar
The key to doing it right, is to not give it a wimpy lift of the shift lever on the way up. Do it with some authority!
Old Mar 30, 2006 | 07:35 PM
Turboedsupe's Avatar
You can adjust the way it shifts. I did it on my bike, when i first got it it was hard to downshift and easy to upshift. You just take the 10mm bolt off and move the connector up or down a tooth to your liking
Old Mar 30, 2006 | 11:47 PM
dondi's Avatar
If the shift lever connecting rod is adjusted such that the shift lever is too high then it can be difficult or impossible to get into second gear. (Don't ask me how I know that...)
An easy experiment is to adjust your shift lever down just a couple of millimters and see how it responds.
The shift lever connecting rod has a lock nut at each end. I believe the forward nut is left handed threads.
Back those off a bit and then rotate the rod so that your shift lever drops just a tad.
Tighten up the lock nuts up and then take a short ride... and see if that helps.
Old Mar 31, 2006 | 04:54 PM
vtec97hatch's Avatar
ORIGINAL: plasteredbassist
i have this same problem if i dont rellay jam on i and just kinda half *** shift i go to neutral too u just have to make sure u press hard enough
+1
Old Apr 1, 2006 | 01:35 AM
jorge13's Avatar
+1, +1
Old Apr 1, 2006 | 08:36 AM
shraz's Avatar
when I put mobil mx4t full synthetic oil, the bike shifts way better
I used to miss alot when going slow from first to second too but now i barely do
but yeah like ppl said shift at higher rpm
Old Apr 1, 2006 | 10:38 PM
Just adjust the shifter a normal tranny should not have any problems shifting. Make sure your hitting it up though pretty good, but ramming should not be needed
Old Apr 2, 2006 | 05:37 AM
snobrdrdan's Avatar
ORIGINAL: Turboedsupe
ramming
Made me think of Farva saying: "Car RamRod"
lol
(the movie SuperTroopers if you didn't get it)
