Gear indicator - help
Old Jun 17, 2012 | 08:34 AM
jdmdohcpower's Avatar
Default Gear indicator - help
Hey guys, I was trying to put on a Healtech gear indicator which I have done on my yamaha before. But, on my 02 f4i I cant find the speed sensor connection where the harness connects. Any ideas?
Thanks
Old Jun 18, 2012 | 11:19 AM
City Bike Racing's Avatar
June 2012 Ride of the Month
80+ views and none of us have a clue i guess.
Old Jun 18, 2012 | 11:27 AM
74demon's Avatar
I figured that one of you F4i guys would help a brother out...
On my 929, which is probably the same, the speed sensor is in the top of the transmission. Follow the harness up to the bundle of connectors. It's a black, 3 pin connector in there somewhere. There may be more than one 3 pin in there, so make sure it's the one you're looking for.
Old Jun 18, 2012 | 02:15 PM
zimdbw74's Avatar
Referencing the manual, like demon said its a black 3 pin connector. You should have a black, green, and pink wire. The Honda manual calls for removal of the throttle body to access it, I can't say from experience if this is necessary or not but that's what its saying to do. Maybe someone that has dealt with this connector can say yay or nay on throttle body removal.
Old Jun 18, 2012 | 09:53 PM
curley444's Avatar
It's above the transmission behind the cylinders just where it's supposed to be, it's just hard to find. I swear it took me an hour to find mine when I bought a speedoDRD to correct the speedometer after I changed my gearing. And they're are right it's a 3 pin black connector it's the only one like it in there. I didn't remove anything to get to mine it just took a while. But then again I have tiny hands. Good luck.
Old Jun 19, 2012 | 08:42 AM
Sick97SS's Avatar
Its a PITA to get to for sure.
DonnyBrago tells you just how to get to it
Old Jun 19, 2012 | 10:48 AM
Thanks for the info guys, I have the service book and I know where it was "supposed" to be. Just didnt have any luck finding it. I think I will burn off what fuel is left in the tank and try that method of lifting the tank out of the way with the strap so I can see down, not looking from the sides. Maybe that will help.
Thanks again guys
subyman1440
Nov 15, 2012 09:57 AM
speediseverything
Aug 17, 2007 04:57 PM
f4iguy8804
May 9, 2007 04:58 AM
Handan
Dec 16, 2006 05:03 PM
dlbinford
Apr 27, 2005 01:55 AM
