gauges wont work! pls help
Old Apr 25, 2006 | 03:18 AM
turboner's Avatar
Default gauges wont work! pls help
just got an f4i today everything was working great before i pulled over and gassed it up, i opened the tank and found that it was still full, closed it and was on my way, i noticed that after i closed the lid, my gauges wouldn't work when i started up the bike and when it was off the fi light remained on and now i'm worried that it would drain the battery! some help would be appreciated.
Old Apr 25, 2006 | 03:24 AM
HonG's Avatar
Default RE: gauges wont work! pls help
try checking ur fuse...
Old Apr 25, 2006 | 04:07 AM
jdiggity's Avatar
i concure... sounds like you need to replace a fuse.
Old Apr 25, 2006 | 10:52 PM
turboner's Avatar
i checked every fuse, they all look good every time i turn off the bike the fi light comes on and the screen it says < A > blinking is that some kind of a check engine light?
Old Apr 26, 2006 | 11:51 AM
DanGrim's Avatar
Is it just your speed that's not being shown? I had that happen to me. Fix was easy though, just repalced the sensor in the tranny. Check to see if the FI light is blinking a code when it goes on. Then repost with the number of flashes, that should give you a good idea of where the problem lies.
Dan
Old Apr 26, 2006 | 07:58 PM
turboner's Avatar
actually the speedo screen was totally blank and the tach was staying at 1,800 all the time even with engine off and running, anyway i solved the problem opened up the cluster gauge and the link connector was disconnected hehehe dont know how it came off though looks pretty solid to me. thankx for your help
C Jacob W
Jul 29, 2013 11:03 AM
smalls89
Apr 6, 2011 08:08 PM
Rwillride17
Aug 25, 2007 01:02 PM
locogato11283
Apr 23, 2005 02:48 AM
