Gas tank leak
Old Mar 13, 2013 | 08:32 PM
jacksla3's Avatar
Default Gas tank leak
Hey, is there a special gasket sealant for use for where the fuel pump meets the tank?
Old Mar 13, 2013 | 10:31 PM
stlcbr600f4_newb's Avatar
yes it is suggested in the manual that you replace the "fuel pump packing" after every removal.... but it you have a leake and recently removed the fuel pump and have a leak .. remove and check for the stainless packing strands aren't caught in the gasket..
had the same issue that's all it was i have removed and installed my pump 4 times with the same packing... and you have to do cross over tightening ... for even and uniform seating of the pump
Old Mar 13, 2013 | 10:39 PM
mnguyen84's Avatar
unless that big rubber gasket is damaged..it shouldn't leak if u bolted it on correctly. ask the dude at Autozone about the sealant thing.
dsenk48
How-To: Mechanical
Sep 22, 2013 08:09 AM
smallsoldier48
Feb 12, 2012 05:36 PM
SACBR
Jun 19, 2011 11:09 PM
cbrryno
Oct 27, 2010 11:09 AM
wbraray
Mar 13, 2010 09:08 PM
