oil change time. quick question
Old Mar 12, 2013 | 12:39 PM
1 oblivion i's Avatar
Default oil change time. quick question
so im getting the bike ready for spring and was gonna do an oil change.. i went to a shop and asked for some oil and he gave me SAE 10w-40 Kawasaki motorcycle performance oil... should i use this oil ? or should i return it and get a different kind?
Old Mar 12, 2013 | 03:10 PM
chambers's Avatar
The oil they gave you is fine, but you can get a gallon of rotella t6 5w-40 synthetic at walmart for about $20 or if you want to use conventional you could use rotella triple t 15w-40 for about $13.
Old Mar 12, 2013 | 04:12 PM
ahh ok, thanks for the quick response and info
Old Mar 12, 2013 | 05:48 PM
boredandstroked's Avatar
oem honda conventional is only $5 a quart at the dealer as well.
Old Mar 12, 2013 | 10:17 PM
kevin...who?'s Avatar
10W-40 is recommended for the F4i. You would be safe using that oil if that is your concern.
Many people on the forum here run Shell Rotella T6 as chambers said because it's cheap, easily obtainable, and comes in gallons. I personally run Rotella T6 on both my F4i.
Just remember once you go full synthetic, you can't go back to regular oil.
Old Mar 12, 2013 | 10:29 PM
stlcbr600f4_newb's Avatar
BIG thing to think of do you have a OEM clutch or after market????? depending on what you have the friction reducers in synthetic can cause havoc on certain clutch disk... oem clutch go synthetic you should see some improvements in temps and smoothness of the bike.... synthetic is extremely uniform at a atomic level and provides the best flow through the engine....
Old Mar 12, 2013 | 10:49 PM
Taw1985's Avatar
Not to Hi-Jack this thread. When going full Syn Oil how would one proceed? Just do a Reg Oil change and put in new oil and filter and run with it or put in new oil and filter and run bike for a lil while to flush the old oil out like a radiator flush?
Right now I am running standard Honda Oil and me being OCD on a newly acquired 600f4i with 30k On the clock I like to make her last as long as possible.
Old Mar 12, 2013 | 11:15 PM
CorruptFile's Avatar
June 2013 ROTM
Do a full drain (from a hot engine). No need to flush your system.
Old Mar 12, 2013 | 11:31 PM
Taw1985's Avatar
Thank You!
I am in the midst of writing up a common issues and maintenance article to post up and hopefully be stickied. I've only been a member a little while but I see no common questions asked thread.
Old Mar 12, 2013 | 11:36 PM
June 2013 ROTM
No problem.
We're all broken records here.
