Gas Tank issue..
Old 06-05-2013, 11:47 AM
John Cu's Avatar
Default Gas Tank issue..
Hi everyone.
I have an issue with my gas tank on my both bikes (f4i), when i remove the tank there is no problem BUT when i try to reinstall it the 2 upper screws does not fit easy, its a pain in the a** to put them back on.
Does any one knows why this happens???
In this pic you can see my steering damper that fits in these screws..
Old 06-09-2013, 09:14 PM
John Cu's Avatar
Nobody???
Old 06-10-2013, 01:28 AM
rd91si's Avatar
I usually put the top ones in first leave them really loose and get the bottem ones started.
Old 06-10-2013, 09:59 AM
John Cu's Avatar
i've tried that way but is the same thing, i dont know why!
Old 06-10-2013, 10:04 AM
bigboi18184's Avatar
My top two will not thread unless I remove the rubber grommet that goes in between the tank and frame. Getting getting longer bolts to try and fix it this weekend.
Old 06-10-2013, 10:15 AM
John Cu's Avatar
That's what im talking about!! but why?? i can try 2 hrs putting them on and nothing!!! thats a pain in the *ss...
Old 06-10-2013, 10:25 AM
If you pull the rubber grommet off and put the bolt through it you will notice only a few threads come out. So like mine I'm thinking the first few threads in the frame are stripped. This is why I'm looking for some longer bolts to put in mine so that they will catch a thread.
For now I just pulled the rubber grommets out and it bolts in fine.
Old 06-10-2013, 10:35 AM
Spook155's Avatar
Sometimes, issues with putting the tank bolts in is indicative of a bent frame/tucked neck. It'd be good to get it checked out, better safe than sorry.
Old 06-10-2013, 11:30 AM
John Cu's Avatar
I know it can be a Bent frame but in my 2 bikes??? F4i '05 and F4i '02...
Old 03-27-2014, 12:37 PM
RT Lindall's Avatar
any conclusions?
Quick Reply: Gas Tank issue..
