Gas Tank issue..
1 Attachment(s)
Hi everyone.
I have an issue with my gas tank on my both bikes (f4i), when i remove the tank there is no problem BUT when i try to reinstall it the 2 upper screws does not fit easy, its a pain in the a** to put them back on. Does any one knows why this happens??? In this pic you can see my steering damper that fits in these screws.. Attachment 22087 |
Nobody???
I usually put the top ones in first leave them really loose and get the bottem ones started.
i've tried that way but is the same thing, i dont know why!
My top two will not thread unless I remove the rubber grommet that goes in between the tank and frame. Getting getting longer bolts to try and fix it this weekend.
Originally Posted by bigboi18184
(Post 1236846)
Originally Posted by John Cu
(Post 1236850)
That's what im talking about!! but why?? i can try 2 hrs putting them on and nothing!!! thats a pain in the *ss...
For now I just pulled the rubber grommets out and it bolts in fine. |
Sometimes, issues with putting the tank bolts in is indicative of a bent frame/tucked neck. It'd be good to get it checked out, better safe than sorry.
Originally Posted by Spook155
(Post 1236854)
any conclusions?
