Fuel Tank Question
Old Jan 20, 2013 | 09:43 PM
Default Fuel Tank Question
Is the fuel tank on a 2006 CBR 600 F4i metal or composite ? I know it's a simple question, but I don't have one or know anyone that has one to ask (except all of you naturally).
Old Jan 20, 2013 | 10:20 PM
LasVegasHarley's Avatar
it is made of steel. magnetic tank bags stick to it.
Old Jan 20, 2013 | 11:01 PM
Thanks LasVegasHarley, that's exactly what I was looking for.
Old Jan 21, 2013 | 10:14 PM
Default Follow-up question
On a 2006 F4i, does the seat come off easily ? Can you access the battery from there?
Old Jan 21, 2013 | 10:56 PM
Banana Seat Removal:
1. Insert ignition key into seat lock (located near license plate mount)
2. Turn key clockwise
3. Pull seat back and up
Yes, the battery is there under the seat.
Old Jan 21, 2013 | 11:11 PM
Super... that's twice in a row... you're on a roll man.
Thanks again.
Old Jan 23, 2013 | 08:21 PM
OK, a couple of additional follow up questions. None of these additional questions are worthy of creating another thread (I don't think so anyway).
Regarding the Clip-On's. How thick (or tall if you will) is the Clip-On ? What I mean to say is what is the thickness or distance from the upper surface of the clip-on to the bottom surface. The bottom surface is the part that would be in contact with the upper TrippleTree bracket.
As an example, on my F3, they are 33 mm thick. On my 1000F, they're 34 mm thick.
What are the bolt sizes of the pinch bolts for the fork tubes ? Meaning is it a 14 mm wrench on the uppers and a 6 mm allen wrench for the lower or what. (just offering examples of what I'm looking for)
Old Jan 23, 2013 | 09:43 PM
RudyGT's Avatar
looks like 28mm to me and its 12mm for the axle pinch bolts and for the clip on pinch bolt
actually i think it may sit down further than that.. i dont remember, sorry
edit again, actually after looking at some pictures i don't think it does because there is a notch that lets you move it slightly that goes to the outside of the tripple
instead of inside the tripple.
i love editing...
while that image last, that is the notch i am talking about it sits outside of the tripple
Old Jan 23, 2013 | 11:12 PM
Thank you for that beautiful image. That shows it perfectly. The manual shows that the installation of the Fork Tube should extend 33 mm above the upper TrippleTree Bridge surface. So if I had a bike that was lowered a significant amount, then the following would be the easy way to get it back to factory.
Given that the Clip-On is 28 mm thick, that leaves 5 mm of Fork Tube to extend above the Clip-On. If I loosen the Clip-On's and raise them up until there is only 5 mm above them, then tighten them in place. Next I would raise the front of the bike so that the bike were suspended by the TrippleTree. Then loosen the Fork Tube pinch bolts and allow the Fork Tubes to slide down until the Clip-On's hit the upper bridge of the TrippleTree, then tighten the pinch bolts to spec.
This forum is such an excellent resource of information !
Old Jan 24, 2013 | 09:08 AM
RudyGT's Avatar
sorry i misread what you wrote the bottom of the tripple is 14mm everything else should be 12mm.
you also may want to leave a MM over for the forks or half of one, because i did a pretty damn precise measurement and i cant fit the circular clip on top of my clip ons.
you can see the ring in the picture but there is no clip inside.
odano1988
Sep 15, 2015 07:26 AM
Nikephenom
Jun 16, 2012 10:34 AM
rrasco
May 2, 2012 11:09 AM
loyerj2
Aug 6, 2009 11:01 PM
BadLag
Mar 27, 2008 09:07 AM
