Fuel system cleaning
As soon as I saw PC, I shoulda just asked you to check pulse. I had the same exact problem but mine only turned about to be a bad ground. Check all your grounds, make sure the PC itself is grounded, (seperate cable). Next, I would plug it back in and then check for pulse, that would surely tell you its the PC. Cheers.
Yea, with PC connected, pull the plug off the injector (4) and pop in a test light, you can use your headlight with a paper clip attached. stick it and crank the starter. If it flashes you are getting pulse, if not, nothing. its probably whats causing your problem. Re-connect it right and then check it out. I am not sure about the Pos connection. Probably nothing because its not "grounding". Maybe check fuses? The PC could also be fautly. They are known to be fautly, this is why you can send it to Dynojet and they will repair if possible for like 30 bucks. Good luck.
